Axminster Engineer Series Powerfeeds
AX978155
AX978155
- Provides a smooth, variable speed drive to the traverse of the table
- Simple controls for left/right movement
- Auto stop in any position on the table provided by movable stops
- Protected to IP67 standards, suitable for use with coolant systems
- Simple to fit, choice of models for different machines
Show more
Show less
A very useful power feed system for the X axis to provide a smooth, variable speed drive to the traverse of the table. This will enable control of the cut finish to a much greater extent than achievable by hand. With simple controls for left/right movement and auto stop in any position on the table provided by movable stops, overload protection. Switches protected to IP67, so can be used with coolant systems fitted. Simple to fit and powered by a standard 230V three pin plug, so no wiring is required.
Feed Speed | 100 mm/min to 300 mm/min (var) |
