Axminster Engineer Series SC4 Floor Standing Lathe
720617
From £2,689.98 £2,241.65
4 Reviews
In Stock - Ready to dispatch
  • Axminster Engineer Series SC4 Bench Lathe
  • High quality lathe suitable for workshop or school use
  • Electronically variable spindle speed range of 125-2,000rpm
  • 1,000W high torque, brushless motor gives near silent running
  • Metric and imperial thread cutting, simple change wheel setting
  • Full range of accessories available, tooling, steadies etc.
  • Axminster Engineer Series SC4 Floor Stand
  • Floor stand for the Axminster Engineer Series SC4 lathe
  • Made from welded steel, incorporating two storage cupboards
  • This stand complements the lathe very nicely
  • Includes drip tray
  • Show More
Package deal comprises Axminster Engineer Series SC4 Bench Lathe and Engineer Series SC4 Floor Stand.
This compact lathe of very modern design has many convenient facilities ideal for the enthusiastic model engineer, small component manufacturer or in a teaching environment. A very rigid induction hardened cast iron bed with ground slideways gives a high level of precision. The lathe has 510mm between centres, with a 210mm swing over the bed. This model has a 1,000W brushless DC high torque motor giving near silent running. A standard feature is the full electronic speed control with digital readout of spindle speed, accessed by a push button control panel. Included, as standard, are a 4-way indexing tool post with 10mm tool shank capacity, transverse adjustment on the tailstock for taper turning, rear splash guard and a 100mm 3-jaw chuck.
This is the floor stand for the Axminster Engineer Series SC4 lathe. Made from welded steel and incorporating two storage cupboards, this stand complements the lathe very nicely. With just the rear panel to assemble, this stand is nice and easy to put together. Includes drip tray.
Warranty Engineer Classification & 3 Year Guarantee
Axminster Engineer 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Engineer machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
5.00 4
