Axminster Woodturning S Shaped Tool Rest
104142
From £27.78 £23.15
73 Reviews
  • The ideal support for small to medium bowl turning
  • 19mm diameter highly polished round steel bar
  • Tool glides smoothly for greater control and even finish
  • Shape minimises tool overhang, eliminating chatter
  • Two radii: approximately 50mm and 65mm
  • Equally effective when used inside or outside a bowl
  • Requires matching tool post, purchased separately
  • The tool rests are fully interchangeable with the tool posts
For the smoothest turning
The Axminster Woodturning Tool Rest System is made entirely of stainless steel which means it's corrosion and rust free. The chisel glides seamlessly across the rounded bar without any nicked interruptions.
There are two simple steps...
The stainless steel round bars form the perfect tool rests and screw into the posts. Choose a selection of straight and curved rests - plus a mounting plate - to suit all your turning projects. Each of the accessories will fit a single tool post so it's easy to swap between them as you turn!
Axminster Woodturning Traditional Tool Rests are also available. These feature a large, round, hardened steel bar which is welded on top of a cast steel rest.
1. Select a post
Choose a diameter to suit your lathe
  • 12mm x 81mm long
  • 16mm x 110mm long
  • 19mm x 115mm long
  • 25mm x 140mm long
  • 25.4mm x 128mm long
  • 25.4mm x 180mm long
  • 30mm x 180mm long
Buy tool rests
2. Choose your rests or mounting plate
  • 100mm - for working in confined spaces, ideal for box making
  • 150mm - a middleman for general size turning!
  • 200mm - for gaining more access and supporting the chisel when turning deep inside vases and other hollow forms
  • 250mm - long length allows for deep support for the chisel inside bowls or longer pieces between centres
  • 300mm - available in the Axminster Woodturning Traditional Tool Rest range
  • S Shaped - gain greater control and get closer to the bowl when turning
  • Mounting plate - useful for when you're carving, drilling, finishing etc
Buy accessories
This 19mm diameter highly polished round steel bar has an S-curve shape. The shape makes it ideally suitable for turning bowls.
The rest’s curvature allows you to get closer to the work and minimises tool overhang. This gives you greater control than a straight rest would allow thereby eliminating vibration and tool chatter. The polished surface ensures your turning tools have a smooth transit as you hollow or refine the shape of the bowl. The S-shape has 2 different radii, measured on the outside of the curve; they are approximately 50mm and 65mm. Overall, the rest is 110mm long, giving plenty of potential for small to medium size bowls.
In order to make the system as economic as possible, Axminster produces the tool rests and tool posts as separate items. Before selecting a tool rest you need to purchase a tool post. The tool rest screws onto the tool post. The tool post will fit any of the tool rests. Additional tool rests simply screw onto the same tool post. Spanner flats ground onto the tool post help fitting or removing the tool rest. Once screwed onto your tool post, these 2 parts form the ideal support for all your turning tools.
British Made British Made
4.80 73
