Axminster Workshop 100mm Flexible Extraction Hose Kit
AX806700
AX806700
- Lengths of high quality wire reinforced 100mm hose
- Rubber end cuffs to suit extraction outlets 100-110mm
- Ideal for mobile workshop chip and dust extractors
Show more
Show less
Lengths of high quality smooth bore flexible 100mm extraction hose complete with rubber cuffs at each end. 2 or 4 metres long, this is ideal for those with a single mobile extractor being used on various machines around the workshop. The rubber cuffs allow quick and easy connection as there is a degree of elasticity to accommodate extraction outlets around 100-110mm diameter. Supplied with 2 hose clips.
Hose Diameter | 100 mm |
