Axminster Engineer Series Ground Angle Plates 100 x 100 x 100mm
800302
800302
From £18.58 £15.48
  5. Half Star
2 Reviews
  • Close grained cast iron
  • Precision ground on faces and ends (±0.01mm per 150mm)
  • Work holding device for milling and drilling machines
  • Precision ground and cast iron construction
  • Used to hold work piece square when marking out
  • Either mount on to a table using a clamp or drill to suit studding and T-nuts
  • Dimensions 100 x 100 x 100mm
Manufactured from close grained cast iron these angle plates are precision ground on the faces and ends to give accurate results when marking out or machining. These angles plates are precision ground, flat and square having and accuracy in paralellism and squareness within ±0.01mm per 150mm length.
4.50 2
