Axminster Workshop Hook & Loop Self Adhesive Disc
AX842345
AX842345
- Easy conversion of disc sanders
- Hook and loop allows quick disc changes
- Discs can be re-used, no waste
- Self stick discs; 227mm or 305mm diameter
Show more
Show less
Features hook and loop, self adhesive backing, to enable the use of hook and loop backed abrasive on larger disc sanders. A very economical way of working as the abrasive can easily be removed and re-used at a later date. Supplied in either 227mm or 305mm diameters.
