Axminster Workshop No.1 Dowelling Jig
410233
From £63.78 £53.15
  5. Half Star
43 Reviews
In Stock - Ready to dispatch
  • Use to produce strong edge to edge and butt joints
  • Heavy aluminium extrusions sliding on steel bars
  • Supplied with hardened steel bushes and 2 clamps
  • For 6mm, 8mm & 10mm dowels
Form either E or L joints in timber up to 32mm(1.1/4") thick. This aluminium extrusion jig slides on steel bars and the bushes are made from hardened steel and are replaceable. A clamp is provided on the main part of the jig for holding the timber during drilling and also a second clamp for securing the boards together whilst the position of the jig is being adjusted. Holes are drilled in both boards at the same setting so an accurate line-up guaranteeing. This jig produces an excellent result. Accommodates 6mm, 8mm and 10mm dowel holes. Supplied with hardened steel bushes for 6mm, 8mm and 10mm dowels.
4.30 43
