Axminster Engineer Series Dial Gauge
310453
From £22.78 £18.98
  4. Half Star
7 Reviews
In Stock - Ready to dispatch
  • 50mm diameter
  • 10mm travel
  • Two movable setting tabs
  • Mounting by 8mm diameter stem or 1/4" hole on back
A high precision 50mm diameter dial gauge with a 10mm travel, one millimetre per revolution sub divided into tenths and hundredths giving a resolution of 0.01mm per division. There are two movable setting tabs on the dial and a bezel which can be rotated for zero setting. Mounting is either by the 8mm diameter stem or by using the lug on the rear with its 1/4" diameter hole.
3.60 7
