Axminster Professional Angle Rule
- Patented marking holes every 1mm along the rule for error free, precise markings
- Dual-face slots enable markings to be transferred from one face to another
- Ideal for layouts along the edge of a board or workpiece
Measuring & Marking
Clearly identifiable scale
The tools are easy to read, and the patented marking holes every 1mm ensure error free, precise markings.
Versatile alignment options
The removable T-bar allows for precise alignment and measurements, whatever your project.
Scope of application
The versatile tools enhance the precision of your woodworking projects due to the transparent crosshairs.
Strong and sturdy
Made of stainless steel, the products are wear resistant and will provide a long service life.
Axminster Professional Combination Square Set 150mm (3 Piece)From £36.68 £30.57
The Axminster Professional Angle Rule revolutionises accuracy in marking with its patented marking holes and slots. Using a 0.5mm mechanical pencil, it is designed to eliminate measurement errors, with its patented marking holes for precise, error-free markings.
The 180mm rule features slots that run from one face to another, ensuring accurate transfer of markings. It is perfect for edge measurements, with micro-fine holes at every scale line for exact placement. The 90-degree shape fits snugly against workpieces, and it includes two vertical end scales for drawing parallel lines. Supplied with a mechanical pencil and refills for added convenience.
EAN Barcode | 5052511132553 |
