Axminster Professional AP254PS16 Panel Saw - 230V
- Compact design perfect where space is limited
- 1,600 x 316mm fully featured sliding table
- Rear outfeed and side extension tables included
A strong, versatile disc sander that won’t break the bank!
Perfect for any hobbyist's workshop, the build quality and performance of this sander really does speak for itself when you see it in use.
So sure are we of the quality of this disc sander, we cover all parts and labour free of charge for three years! Find out more
Ideal for a range of applications
This disc sander is great for outside curves and sanding 'to the line'. It's also useful for smoothing materials such as wood and plastic, and will also remove small amounts of waste material.
Strong and sturdy design
More than capable of withstanding many types of sanding tasks, the generous cast-iron table tilts to 45 degrees with a slot for adjustable mitre fence.
Plenty of power
A quiet 750W induction motor proves ample power to handle your projects, while a disc brake and NVR switch safeguard you for complete peace of mind at all times.
Axminster Professional Overhead Crown GuardFrom £759.98 £633.32
Axcaliber Premium TCT Saw Blade - 254mm x 3.2mm x 30mm 80TFrom £91.28 £76.07
Axcaliber Premium TCT Saw Blade - 254mm x 3.2mm x 30mm 60TFrom £74.48 £62.07
Axcaliber Premium TCT Saw Blade - 254mm x 3.2mm x 30mm 40TFrom £54.48 £45.40
Axcaliber Premium TCT Saw Blade - 254mm x 3.2mm x 30mm 24TFrom £41.98 £34.98
The Axminster AP254PS16 Panel Saw offers outstanding cutting quality, capacity and flexibility in everyday use A robust chassis in heavy gauge steel and a generous grey cast iron table provide stability and vibration free running.
The 254mm main blade gives a maximum depth of cut of 80mm. The saw blade is carried on a heavy duty spindle ensuring accurate blade control and is driven by a multi V type belt for quiet operation with high reliability. An 80mm scoring blade is standard and is easily adjusted or withdrawn below the table by simple controls. The high efficiency main blade motor has a brake for safe stopping.
The 1,600mm sliding table runs very smoothly, carries a sizable crosscut table and includes a 2,000mm long, telescopic mitre fence complete with twin length stops. The crosscut table can be easily removed, saving space when not needed. Rear outfeed and right hand support tables are included for sheet work. The rigid rip fence has a sliding rail with high/low functions for all types of work. Cam locked to its rail, it is easy to adjust. The handwheel controls are smooth to operate and have retracting handles to save them being knocked. Dust extraction is provided with a 63mm hose on the crown guard leading to a combined 100mm dust outlet for efficient dust control when connected to a suitable extractor.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Axminster Professional 3 Year Guarantee
Machine Classification
Blade Diameter | 254 mm |
Blade RPM | 4,000 rpm |
Blade Tilt | 0° to 45° |
Bore Size | 30 mm |
Dust Extraction Outlet | 100 mm |
EAN Barcode | 5052511124602 |
Max Depth of Cut @ 45º | 57 mm |
Max Depth of Cut @ 90º | 80 mm |
Max Ripping Width | 870 mm |
Min Extraction Airflow Required | 1,300 m³/hr |
Model | AP254PS16 |
Nett Weight | 242 kg |
Overall L x W x H | 1,820 mm x 2,530 mm x 1,180 mm |
Plug Fitted | UK 16A Plug |
Power | 2.2 kW |
Rating | Trade/Professional |
Scoring Blade Bore | 20 mm |
Scoring Blade Diameter | 80 mm |
Sliding Table Dimensions | 1,600 x 316 mm |
Sliding Table Stroke | 1,600 mm with crosscut fence, 1,850 mm w/o crosscut fence |
Sound Power Level LwA [Uncertainty K] | 103 dB(A) [2.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 99 dB(A) [2.0 dB] |
Table Height | 912 mm |
Table Size | 1,020 mm x 1,193 mm |
Voltage | 230 V |
International delivery is unavailable for this product.
