Axminster Professional AP254TS Table Saw - 230V
107646
From £3,299.98 £2,749.98
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
  • Unique design built to exacting standards with cast iron table
  • Super smooth blade adjustment controls, quick change riving knife
  • Cast iron R/H side extension table machined to take a UJK router plate
Its strong, rigid and powerful body is only the start of this super smart saw
With new optional sets and accessories you're also able to rout and make dado cuts!
Find out more on our blog
Did someone mention Dado?
Made up of two TCT saw blades and six chipper blades, the Dado Blade Set is an optional accessory and enables you to achieve exceptional tongue and groove slots. The optional Overhead Crown Guard accessory ensures this feature complies with all current Health & Safety regulations. There is a quick release catch to make it simple to switch out the riving knife for the dado set.
Highly recommended
The use of the Overhead Crown Guard which ensures the blade is effectively guarded (please see the HSE website for additional guidelines).
Use the table saw as a router table
The cast iron right hand extension table is recessed to incorporate a router table insert and is compatible with the UJK Router Fence, UJK Router Elevator or more basic UJK Router Insert.
Turn the saw into a small panel saw
The optional ST1400 Sliding Table has an exceptional 1400mm stroke and is 1200 x 230mm in size. A separate 335 x 230mm outrigger table comes with it offering extra support.
Upgrade to a Zero Clearance Insert
Replace the standard kerf plate with the Zero Clearance Insert. For use only when the blade is at 0°, it sits extremely close, a mere 0.5mm from the blade. As well as preventing the waste from dropping beneath the table it also helps support smaller work, allowing finer cuts.
3 Year Guarantee
For complete peace of mind, we cover all parts and labour free of charge for three years.
Exacting precision during manufacture and a very high build quality result in a machine that stands out above all others.
The design centres around a heavy duty welded steel stand, to which is attached the entire workings of the machine. A massive, curved iron casting supports the motor and blade arbor, giving huge rigidity and blade support. This leaves the table completely unstressed and gives superb, smooth control of blade height and tilt adjustments.
The cast iron table has twin 19mm mitre fence slots. The kerf plate is adjustable to the table surface. The riving knife is easily removed by releasing a simple latching pin. The full length rip fence with a T-square style mounting, glides smoothly and locks rock solid in position. A Hi-Lo sliding fence rail is included.
The AP254TS comes with a cast iron, right hand side extension table, which doubles as a router table. It is machined to take a UJK 10mm Router Insert Plate or UJK Router Lift. Twin grooves are machined into the extension table for mounting a UJK RT-100 router fence.
This table saw can be added to with several optional extras, including a 1,400mm sliding table complete with a UJK sliding table fence, the S-12 Overhead Crown Guard System, and a Dado Blade Set.
Supplied with a top quality TCT blade, this table saw will suit any busy professional workshop
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Machine Classification
4.60 13
