The AP2770BS oscillating belt sander includes several well thought-out features. Suitable for any medium sized joinery workshop or cabinet maker's workshop, it is very well guarded and easy to use. It can be used horizontally or vertically; the belt oscillates 50 times per minute providing a scratch free finish. In the vertical mode the work table can be raised by means of a hand wheel and adjusted to minimise the gap to the sanding belt. A large quadrant scale gives an accurate indication of the belt to table inclination for bevel work. Incremental stops are included for most popular angles. An additional use is as a small vertical drum sander with the fitment of any of the three bobbins (38mm, 50mm and 75mm) supplied, using a small table assembly surrounding the idler roller. A robust, welded steel stand supports the whole machine and has a large cupboard for storing sanding sheets and accessories. Twin 100mm dust ports provide dust free operation when connected to a suitable fine dust extractor. A very well made and invaluable machine in any workshop.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Machine Classification
