Axminster Professional AP355PS32 OHCG Panel Saw - 415V
107664
From £7,999.98 £6,666.65
1 Review
  • Enquire - contact us for a personalised quote
  • Big cutting capacity with high level of accuracy
  • 355mm blade offers 115mm maximum depth of cut
  • 3,200mm heavy-duty sliding table with panel support
  • 120mm scoring blade with separate motor
  • Large smooth precision ground cast iron table
  • Extendable cross cut fence with dual flip stops
  • Overhead crown guard for safety and improved extraction
This heavy-duty panel saw offers a high precision cutting with big cutting capacity. The AP355PS is fitted with a smooth gliding 3,200 x 360mm sliding table. This offers a full 3,100mm in front of the blade for cutting large sheet materials.. The sliding table features a cam-lock hold down clamp, edge shoe and an adjustable handle. The panel support frame features an extendable mitre fence and two flip-over length stops. Both saw and sliding table are carefully matched and factory set.
The AP355PS takes either a 305mm or 355mm diameter blade, giving the potential for a maximum depth of cut of 110mm using the larger diameter blade. The 120mm scoring blade is powered by a separate motor.
The main table is rigid, precision ground, cast iron. The cast iron rip fence bracket features fine adjustment and a long Hi-Lo auxiliary fence. Rear outfeed and side extension tables come as standard. The overhead crown guard greatly improves dust extraction and safety. A 96T fine crosscut 305mm blade main saw blade is supplied along with a riving knife for 355mm blades.
Please ensure that your workshop electricity supply is adequate for these machines. If unsure, seek advice from a qualified electrician. N.B. 32A supply is required, (5 pin, 3 x L, N + E for 415V supply).
Machine Classification
5.00 1
