If you regularly finish boards, panels and frames, this twin drum finishing sander is just the ticket.
Achieve a fine finish
Dynamically balanced 125mm twin drums eliminate vibration to give a fine finish in one pass.
Great results, every time!
The rubber conveyor belt gives a clean, non marred finish for a professional finish
Accuracy, guaranteed
The solid steel construction and cast iron frame ensures accurate machining, making it an invaluable addition to any small workshop.
Ready, set, go!
The easily accessed adjustments means the sander is quick and easy to set up. Understanding that time is money, you'll be at work in the blink of an eye.
3 Year Guarantee
For complete peace of mind, we cover all parts and labour free of charge for three years.
This twin drum finishing sander has a compact footprint and is designed for finishing boards, panels and frames.
The sanding drums are aluminium, machined and dynamically balanced for smooth running. The drums are powered by a 1.5kW 230V. Being a twin drum machine, it uses a different grade of abrasives on each drum, coarse on the front, fine on the rear. The rear roller will require adjustment depending on the abrasive being used. A graduated scale for each side makes accurate setting an easy task. The abrasive is easy to change, requiring no tools. The access lid has a safety interlock switch.
A separate variable speed motor drives the conveyor, giving a wide range of feed speeds. A convenient crank handle and scale are provided for easy adjustment of thickness.
Dust extraction is via twin 100mm dust outlets, we recommend the use of a 2.2kW fine dust extractor as a minimum.
Machine supplied with two abrasive loadings (80 grit and 120 grit).
N.B. Drum sanders are used as part of the finishing process, they are not intended to be used as a planer/thicknesser or for significant stock removal. A drum sander does not replace a planer/thicknesser and vice versa. Drum sanders are intended to be used with already planed and thicknessed material. Overall a planer/thicknesser is meant to dimension timber, the drum sander to finish it.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Machine Classification
