Axminster Professional Dado Blade Table Insert
109598
From £20.68 £17.23
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Table insert for AP254SB when using dado blade
  • Replaces standard table insert
  • Aluminium with 25mm wide slot
This table insert fits the AP254SB Professional Saw Bench. It is required when using a dado blade, replacing the standard insert. The slot is 25mm wide to accommodate the dado blade. It is used with the saw blade set at vertical only. Made from aluminium.
