Axminster Professional Wide T-Rule
109958
From £11.98 £9.98
  5. Half Star
7 Reviews
In Stock - Ready to dispatch
  • Designed for dead-on accuracy with the included 0.5mm mechanical pencil
  • Thin construction avoids parallax issues, improving the accuracy of your projects
  • Suitable for end/edge marking, parallel and perpendicular line drawing, and vertical measurements
  • The T-Bar ensures accurate alignment and measurements, with easy adjustments if necessary
  • Length: 200mm, depth: 70mm
Measuring & Marking
Clearly identifiable scale
The tools are easy to read, and the patented marking holes every 1mm ensure error free, precise markings.
Versatile alignment options
The removable T-bar allows for precise alignment and measurements, whatever your project.
Scope of application
The versatile tools enhance the precision of your woodworking projects due to the transparent crosshairs.
Strong and sturdy
Made of stainless steel, the products are wear resistant and will provide a long service life.
The Axminster Professional Wide T-Rule is a meticulously designed tool that ensures error-free marking for enhanced project precision. It simplifies precision marking and measuring, whether you're working along the edge or end of your workpiece, or need to draw lines parallel or perpendicular to the edge.
The wide rule has been specifically tailored for various marking and measuring applications, and the 70mm width allows for increased accuracy across more varied woodworking projects.
Its slim design minimises parallax errors, and the T-Bar alignment ensures accurate measurements. The T-Rule comes fully assembled, but if adjustments are needed, the T-Bar can be easily repositioned against the indexing lip before tightening to maintain accuracy. The tool is essential for any project requiring precise measurements and markings. Supplied with a mechanical pencil and refills for added convenience.
4.60 7
