Rider Sharpening Station
101171
101171
From £69.98 £58.32
  5. Half Star
11 Reviews
In Stock - Ready to dispatch
  • Organise sharpening for consistent results every time
  • Designed to work with a Rider Honing Guide or similar
  • CNC machined recesses for sharpening stone and setting bevel angles
  • Supplied with Board, Strop, Paste and instructions (does not include sharpening stone)
Measuring 250mm (10") x 315mm (12") the Rider Sharpening Board is CNC machined from 13mm (1/2") thick synthetic resin laminate. This is the same material used to produce our kitchen worktop jigs. It is unaffected by oil or water and easy to keep clean. Four rubber feet give stability whilst sharpening and ensure the board will not creep across the bench in use.
The stone recess is 228mm (11") x 89mm (3.1/2"), (This matches the Rider Double Sided Diamond Bench Stone). It is a simple matter to hold shorter stones in place using a homemade wedge or spacer to fill any gap. A stone needs to be just snug enough to prevent movement back and forth as you sharpen.
The strop is 203mm (8") x 65mm (2.1/2") quality split grain leather. The strop removes any remaining minute wire edge and puts a final high polish finish on your edge tools. It is a matter of personal preference whether you use it with or without a polishing compound.
Designed to work in conjunction with an Rider Honing Guide it is as effective with similar Eclipse type guides. The edges of the board feature recesses which act as set-up guides for bevel angles of 25°, 30° and 45° for plane irons plus 25° and 30° bevel angles for chisels. This forms a very effect sharpening station with guaranteed repeatability for sharpening or honing angles.
Supplied with: Board, Strop, Paste and instructions (does not include sharpening stone)
British Made British Made
4.60 11
