Axminster Professional Rip Fence Upgrade
100205
From £149.98 £124.98
  5. Half Star
70 Reviews
In Stock - Ready to dispatch
  • Upgrade for old and worn rip fences
  • Simple to fit, set up, and use
  • Ball bearing guiding for easy running
  • Rigid mounting rail and fence extrusion
  • Simple vertical clamping lever
This excellent rip fence upgrade is a godsend to anyone struggling with a worn or sub-standard bandsaw or table saw fence on an otherwise well performing machine. It is made from aluminium extrusions and features ball bearings for smooth running, adjustment for squareness, graduated scales and a quick action locking handle. The support rail fits to the front edge of the saw table with two brackets with holes positioned 23mm below the table surface. The brackets can be positioned along the length of the rail to suit different sized tables. If the table edge is not deep enough then simple angle brackets can be made to mount the rail. The length of the rail is 740mm and the fence is 550mm long by 65mm deep. The fence extrusion has tee slots on three faces for mounting false fences and other accessories. Altogether a very well-produced and effective accessory for upgrading your bandsaw or table saw.
4.70 70
