Axminster Tools Extended 2-Year Warranty
Enjoy the confidence of knowing your Laguna machine is backed by Axminster Tools’ exceptional service and care.
The Axminster Tools’ extended warranty is only available for purchase at the same time as the purchase of your Laguna machine.
Maximise your investment
Axminster Tools optional 2-year extended warranty on all Laguna machines, ensures peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. The extended warranty guarantees that for a period of two years from the original invoice date, the product will be of satisfactory quality, fit for any stated or reasonable purpose, free from material defects in design, material, and workmanship, and compliant with all applicable statutory and regulatory requirements in the United Kingdom.
If any part is found to be faulty, we will repair or replace it at no cost to you, provided you follow the claims procedure. You must have purchased the correct product for your intended purpose and allow us a reasonable opportunity to examine the product if necessary. For dust extractors, the product must be thoroughly cleaned before any examination can occur. This extended warranty ensures that you receive the highest level of service and support for your Laguna machines. For more information, please refer to our Terms and Conditions.
Extended Coverage
The extended warranty provides an additional year of coverage beyond the standard 1-year warranty, ensuring that your machine is protected for a total of two years from the original invoice date. Please note: The extended warranty must be purchased at the same time as your Laguna machine; it is not possible to retrospectively purchase the extended warranty.
Comprehensive Protection
This warranty guarantees that the product will be of satisfactory quality, fit for any stated or reasonable purpose, free from material defects in design, material, and workmanship, and compliant with all applicable statutory and regulatory requirements in the United Kingdom.
Free Repairs and Replacements
If any part is found to be faulty within the 2-year period, Axminster Tools will repair or replace it at no cost to you, provided you follow the claims procedure.
Peace of Mind
Knowing that your machine is covered for an extended period gives you peace of mind and confidence in your purchase.
Expert Examination
If necessary, Axminster Tools will examine the product to determine the fault, either by having you return the product or by sending a team member to your location.
Thorough Cleaning Requirement for Dust Extractors
For dust extractors, the product must be thoroughly cleaned before any examination can occur, ensuring that the machine is well-maintained.
The 2-year guarantee covers parts and labour providing:
- You have purchased the correct product for your intended purpose in accordance with our classification
- The product is operated correctly
- You have maintained and serviced the product in accordance with the instructions (proof may be required)
The Guarantee does NOT cover:
- Products purchased for use outside our classification advice e.g. Workshop product used for business purposes
- Consumable items e.g., original blades, knives, drive belts, abrasives or filters
- Issues identified due to normal wear and tear, misuse and neglect
- The product has been operated with blunt/incorrect tooling
- The product has been modified
Laguna Machines Extended Axminster Tools 2-Year Warranty Terms & Conditions
Thank you warranty provides additional cover for your machine providing you with more support and confidence when using your Laguna machine. This extended warranty is provided under the terms and conditions set out below. Please ensure you retain your proof of purchase (original sale invoice) and warranty certificate, no registration is required.
1. Background
1.1 Definitions
- “We / we”, “Us / us”, “Our / our” – means Axminster Tools, Unit 10, Weycroft Avenue, Axminster, EX13 5PH, registered company number 03326979
- “Extended Warranty” – means the cover provided in clause 2 of this document for the Laguna Product
- “Price” – means the agreed payment made by You to Us in consideration to this Extended Warranty
- “You / you” – means the person that has purchased the Laguna product and the Extended Warranty
- “Product” – means the Laguna Product purchased from Us and with which this Extended Warranty has been purchased.
1.2
To purchase the Extended Warranty, you must pay the Price at the time of purchasing the Product. An Extended Warranty cannot be purchased after the date of the original invoice for the sale of the Product.
1.3
An Extended Warranty cannot be purchased if the original invoice was not issued by Us.
2. Guarantee
2.1
We guarantee that for a period of 2 years from the original invoice date that the Product shall:
- be of satisfactory quality;
- be fit for any purpose we say the Goods are fit for or for any reasonable purpose for which you use the Goods;
- be free from material defects in design, material and workmanship
- comply with all applicable statutory and regulatory requirements relating to the Goods in the United Kingdom.
2.2
We will repair or replace, at no cost to You, any part/s which are proved to be faulty in accordance with paragraph 2.1 provided that:
- 2.2.1 You follow the claims procedure set out in clause 3 below; 2.2.2 You have purchased the correct product for Your intended purpose;
- 2.2.2 You have purchased the correct product for Your intended purpose;
- 2.2.3 We are provided with a reasonable opportunity, after the claims procedure has been followed, to examine the Product. It is at Our discretion as to whether we need to examine the product before issuing any parts free of charge;
- 2.2.4 Where We determine examination is necessary, You agree to return the Product to Us or allow a member of Our team to visit the place where the Product is installed to allow the examination to occur;
- 2.2.5 If the product is a dust extractor and We have deemed that an examination is required, either by returning the Product to Us or We send a member of Our team, then the Product must be cleaned thoroughly by You before any examination can occur;
- 2.2.6 Any fault identified is not as a consequence of: - the Product being used for a purpose that which the Product is not suitable - Issues identified due to misuse and neglect
- fair wear and tear that can be reasonably expected throughout the life of the Product including items such as drive belts and bearings and consumables such as blades and other wearable parts (see schedule 1 which provides a non-exhaustive list of Laguna Products and the parts that are considered wearable) - operating the Product with consumables that are blunt and/or incorrect - modifications made by You that are not supplied as standard with the Product.
- 2.2.7 You have maintained and serviced the Product in accordance with the instruction manual and any other industry best practice guidelines.
3. Claims Procedure
3.1
Firstly, please contact Our customer services team and discuss the Product with US. This must be done within 48 hours of identifying any potential fault with the Product.
3.2
If it is agreed that there is a potential fault with the Product then You are required to write to Us providing Your proof of purchase, images that best highlight the potential fault and an explanation of the problem that has led to the fault.
4. Limitation of liability
4.1
This Extended Warranty is an added benefit that is purchased by You at the agreed Price and only applied to the Laguna Product that You purchased alongside this Extended Warranty.
4.2
This Extended Warranty, and these terms and conditions, does not confer any other rights other than those expressly set out above. All other terms and conditions can be found on Our website at Terms & Conditions | Axminster Tools.
4.3
This Extended Warranty is in addition to Your statutory rights.
Schedule 1
Non-exhaustive list of parts per Laguna machine that are considered wearable;
Laguna Models Parts | Parts considered wearable |
Laguna Revo 12|16 lathe Laguna Revo 18|36 lathe Laguna Revo 24|36 lathe |
Drive belt Headstock bearings |
Laguna 14|12 Bandsaw Laguna 14|BX Bandsaw Laguna 18|BX Bandsaw |
Bandsaw blade Drive Belt Bearings Bandsaw wheel tyres Ceramic guide blocks |
Laguna 16|32 Drum Sander | Sanding Abrasive Rubber duffer spider Bearings |
Laguna A|Flux 12 Air Filter | Filters |
Laguna B|Flux 1 Dust Extractor Laguna C|Flux 1 Cyclone Extractor Laguna P|Flux 3 Cyclone Extractor Laguna P|Flux 3 Cyclone Extractor |
Filters Waste Sacks Waste Sack Straps |
Laguna F1 Fusian Table Saw Laguna F3 Fusion Table Saw |
Saw Blade Drive Belt Extraction Hose Bearings |
Full Axminster Terms and Conditions can be found here. This guarantee does not affect your statutory rights.
