Axminster Professional 280mm Bed Extension for AP350WL Lathe
107031
Last Few
Special Price £99.98 £83.32
was £199.98 £166.65 Save £100.00 £83.33
  5. Half Star
21 Reviews
In Stock - Ready to dispatch
  • Increases lathe capacity by 280mm
  • Easy to fit, simply bolts onto the end of the lathe
  • Machined cast iron, perfect match to existing bed
  • Offers maximum of 680mm (26.3/4”) less centres
  • Fits the Axminster AP350WL and the Axminster AW1416VS
Extend your lathe’s capabilities
Transform your lathe with the Axminster Trade 280mm Bed Extension. Designed exclusively for the AT350WL Lathe, the bed extension provides a cost effective solution to upgrading your lathe, giving you greater turning flexibility.
New design
Our new design is easy to fit - simply bolt it onto the end of the lathe without the need of a stand. The bed extension is cast iron, carefully machined to match the existing bed of your lathe.
The bed extension increases lathe capacity by 280mm, perfect for turning longer pieces such as table legs. It offers a maximum turning space of 680mm (26.3/4”) between the head and tailstock.
Compact design and flexibility
Create more space in your workshop. This bed extension is easy to fit and remove, keeping your benchtop space clear when your lathe is not in use. Leaving you to extend your lathe as and when it’s needed!
Affordable solution
Can’t afford to upgrade your lathe? Then the Axminster Trade 280mm Bed Extension is a cost effective solution, giving you greater turning flexibility without investing in a bigger lathe.
A most useful accessory for the AP350WL lathe (and Axminster AW1416VS). This 280mm bed extension increases the capacity to a full 680mm between the head and tailstock. Depending on your choice of drive and tailstock centre, you will be able to undertake projects up to 610mm (24”) long, chair legs for example. The extension is cast iron, carefully machined to match the existing bed of your lathe; it simply bolts onto the end.
4.70 21
