Axminster Professional Bar Clamp Rack
104701
104701
From £23.98 £19.98
  5. Half Star
32 Reviews
In Stock - Ready to dispatch
  • Organise unruly long clamps, F clamps, sash clamps, parallel jaw clamps etc
  • Extra heavy gauge steel up to 25kg load capacity, holds up to 12 clamps
  • Pre-drilled for wall mounting; made in the UK
See the entire range
This rack will deal with your storage problem in the best possible way. It will safely store your F clamps, sash clamps and parallel jaw clamps.
The storage slots are 12mm wide and the capacity is up to 12 clamps or 25kg. Made of 2mm thick steel with a painted finish they are unlikely to bend under load or rust over time. Each rack is 600mm long and pre-drilled for fixing on a wall.
This is an ideal companion to the Axminster Professional G clamp rack. Tidy up, gain more workshop space and say goodbye to that heap of clamps in the corner.
Made in the UK.
Warranty Axminster Professional Clamps Lifetime Guarantee
British Made British Made
4.70 32
