Axminster Professional G Clamp Rack
- Suitable for any size G clamp from 75m to 250mm, holds 10 G-clamps
- 2mm thick steel, tough painted finish, pre-drilled for wall mounting
- Quick and easy retrieval of clamps; made in the UK
See the entire range
This rack makes a great alternative to trying to retrieve a G clamp from a box under your bench.
The rack provides space for up to 10 G clamps. Your G clamps sit in place, quietly waiting for the next time you need them. The slots ensure quick and easy access for sizes from 75mm to 250mm. Made from 2mm thick steel it has a tough painted finish, the rack is 420mm long by 70mm high and pre-drilled for fixing on a wall.
This rack makes an ideal companion to the Axminster Professional bar clamp rack.
EAN Barcode | 5052511100699 |
Model | E695 |
Overall L x W x H | 420 mm x 100 mm x 70 mm |
