Axminster Workshop Vernier Caliper - 150mm/6"
910359
910359
- Stainless steel with satin finish
- Clear metric and imperial graduations
- Metric scale gives readings down to 0.02mm and the imperial scale 0.001"
- Can be used for external, internal and depth measurement
Show more
Show less
A good quality vernier caliper made from stainless steel with clear metric and imperial graduations and a satin finish to eliminate glare. The metric scale gives readings down to 0.02mm and the imperial scale to 0.001". The caliper can be used for external, internal and depth measurement and the locking screw keeps the head secure between measurements. Supplied in a plastic case.
EAN Barcode | 5052511044542 |
Measuring Range | 0 mm to 150 mm |
