Axminster Workshop AW125BDS Mini Belt & Disc Sander - 230V
107677
From £89.98 £74.98
  5. Half Star
101 Reviews
In Stock - Ready to dispatch
  • Small, disc and belt sander, perfect for toy and model making
  • Versatile machine for detail profiling, finishing or denibbing
  • 125mm diameter disc provided with table mitre fence
A welcome addition to many small home workshops
This Axminster Workshop Mini Belt & Disc Sander enables shaping, denibbing or finishing of wood to be carried out easily and safely.
Compact
Easy to store when not in use, the compact design makes the AW125BDS perfect for those with limited workspace.
Versatile
Excellent for detail work, shaping, denibbing or finishing.
Compounds and mitres
The disc table can be tilted to 45° and features a mitre slot, so both mitres and compounds can be sanded.
Dust extraction
2 x 45mm dust outlets for efficient dust extraction when connected to a suitable vacuum extractor.
A small benchtop sander is an invaluable tool for model or toy makers or woodworkers needing to adjust or finish small parts. The 25mm belt and a tilting table is well suited to profiling, finishing or denibbing. Around the corner is a 125mm diameter disc, provided with its own table and mitre fence and is suitable for end grain work and fine tuning angles and mitres.
All in all, this is an effective small sanding machine with a host of applications for the hobby and craft workshop. 45mm diameter dust extraction outlets are provided for both belt and disc. Supplied with a sanding belt and disc.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Warranty Axminster Workshop 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
4.30 101
