Axminster Workshop AW305WL Woodturning Lathe - 230V
- Powerful 550W DC motor, quiet and smooth operation
- Variable speed from 500 to 4,080rpm
- Cast iron bed, headstock and tailstock provide rigidity, strength and years of pleasure
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
Axminster Woodturning 150mm (6") Tool Rest with 16mm (5/8") PostFrom £10.88 £9.07
Essentials for your woodturning
Perfect for the beginner, these essential tools we'll make it easy to kickstart your woodturning journey.
Understand which lathe is most suited to you with this helpful lathe buying guide for beginners.
Read our full Buying GuideAxminster Woodturning Tools
Start spindle and bowl turning with this great value for money, set of six turning tools. Perfect for the beginner, the tools each come correctly ground and ready sharpened meaning you can start turning straight out the box!
Buy nowLearn to Turn - In store OR online!
Purchase an Axminster Workshop lathe and receive an exclusive discount code to get 50% OFF our Woodturning for Beginners online course. Alternatively, you can visit us in store and enjoy a FREE introduction to woodturning session with one of our staff.
Find out moreThis bench mounted woodturning lathe offers excellent capacity, capabilities and power. The AW305WL has the convenience of variable spindle speed with electronic control.
Power comes from a 550W DC motor providing full torque across the speed range. The spindle speed range is from 500 to 4,080rpm, with a choice of two belt ratios.
Made almost entirely in cast iron ensuring stability and minimal vibration during operation. The bed of this lathe has a finely ground top surface for smooth tool rest positioning. The spindle nose has a 1" x 8tpi thread and a 2MT taper. The tailstock barrel has a 2MT bore with 50mm of movement and automatic ejection of centres. Quick release levers allow for easy and accurate positioning of tool rest and tailstock. Solid rubber feet help to eliminate vibration.
Axminster Workshop 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Distance Between Centres | 457 mm |
EAN Barcode | 5052511125371 |
Headstock Taper | 2 MT |
Lathe Speed | 500 - 2,040 / 1,000 - 4,080 rpm (var) |
Max Diameter over Bed | 305 mm |
Model | AW305WL |
Nett Weight | 40 kg |
Overall L x W x H | 970 mm x 280 mm x 440 mm |
Power | 550 W |
Rating | Home Workshop |
Spindle Thread | 1" x 8 tpi |
Tailstock Ram Travel | 50 mm |
Tailstock Taper | 2 MT |
Tool Post Diameter | 16 mm (5/8") |
Voltage | 230 V |
