Axminster Workshop AW315PD Bench Pillar Drill - 230V
107691
From £279.98 £233.32
  5. Half Star
101 Reviews
  • Sturdy cast iron construction with quiet 550W induction motor
  • 12 belt speeds 210-2,580 rpm for drilling wide variety of materials
  • Convenient rack and pinion table height adjustment
A good size bench pillar drill enabling you to drill accurate holes at consistent depths and angles.
Made from cast iron and machined steel it’s sturdy, stable and strong. The keyless chuck is an excellent feature with a capacity of 1 to 16mm. Powered by a 550W induction motor, there are 12 belt speeds to choose from between 210-2,580rpm. The down feed is fitted with soft grip handles and there is a convenient drilling depth control. Table height is controlled via a rack and pinion system, the whole table assembly can be swivelled away to allow the base to be used as a work support. A front mounted NVR switch and the adjustable chuck guard add to the convenience of use. The belt cover has a safety switch to ensure safe speed changing.
A great choice for any hobby workshop.
Please note: the AW315PD is not suitable for a morticing attachment.
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
4.40 101
