Axminster Workshop White Grinding Wheel 150mm x 20mm 120G
- Sharpen high carbon and HSS tools
- Cooler cutting with less tendency to overheat the steel
- Cuts freely offering a fast result and clean finish
- 150mm diameter x 20mm wide,
This is a replacement grinding wheel for the Axminster AW150BG/AC150BG bench grinder and is suitable for many other 150mm grinders. It has a 31.75mm bore that can be reduced using the Axminster grinding wheel reduction bushes.
White Aluminium Oxide grinding wheels are a preferred choice for general tool sharpening of high carbon and HSS tools.
Compared to general purpose grey grinding wheels, white wheels cut much cooler with far less tendency to overheat a tool’s edge (if you press hard enough for long enough you can still blue the edge). These white grinding wheels have a medium hard vitrified bond with a medium structure. They are friable and cut freely offering a fast result and clean finish.
Bore Size | 31.75 mm (1.1/4") |
EAN Barcode | 5052511124039 |
Grit | 120 |
Wheel Diameter | 150 mm |
Wheel Width | 20 mm |
