Axminster Workshop White Grinding Wheel 200mm x 25mm 60G
- Sharpen high carbon and HSS tools
- Cooler cutting with less tendency to overheat the steel
- Cuts freely offering a fast result and clean finish
- 200mm diameter x 25mm wide,
This is a replacement grinding wheel for the Axminster AW200BG/AC200BG bench grinder and is suitable for many other 200mm grinders requiring a 5/8" bore wheel, 25mm wide.
White Aluminium Oxide grinding wheels are a preferred choice for general tool sharpening of high carbon and HSS tools.
Compared to general purpose grey grinding wheels, white wheels cut much cooler with far less tendency to overheat a tool’s edge (if you press hard enough for long enough you can still blue the edge). These white grinding wheels have a medium hard vitrified bond with a medium structure. They are friable and cut freely offering a fast result and clean finish.
Bore Size | 15.88 mm (5/8") |
EAN Barcode | 5052511124046 |
Grit | 60 |
Wheel Diameter | 150 mm |
Wheel Width | 25 mm |
