Bahco Sandflex H.S.S. Hacksaws Blades
AX23222
AX23222
- Combines high cutting power with exceptional wear resistance
- M2 high-speed steel
- Suitable for all types of metal sawing
Show more
Show less
The Sandflex blade is virtually unbreakable and combines high cutting power with the exceptional wear resistance of M2 high-speed steel. The blades have a degree of flexibility, which is vastly superior to that of ordinary edge hardened or conventional flexible blades. They are suitable for all types of metal sawing, and the preferred choice in our own engineering workshops.
Length of Blade | 300 mm |
