Bahco HGPS Standard Hand Axe - 1kg
- Ideal for all round general-purpose axe
- Thin wide blade for a clean cut
- 380mm long ash handle
The Bahco HGPS hand axe is very much an all round general-purpose axe, with a thin wide blade for a clean cut. Curved ash handle, secured by a jagged carbon-fibre wedge. 380mm long handle with 8mm hanging hole for easy storage when not in use or attaching a lanyard.
EAN Barcode | 7311518123697 |
Head Weight | 0.8 kg (1lb 12oz) |
Nett Weight | 1 kg (2lb 3oz) |
Overall Length | 380 mm |
