Bahco Standard Hand Axe HGPS 0.6-360 800g
Bahco Standard Hand Axe for DIY and hobby use. Very much an all round general-purpose axe with a thin wide blade for a clean cut. Fitted with a curved ash handle, secured by a jagged carbon-fibre wedge. There is also a suspension hole for easy storage when not in use.
EAN Barcode | 7311518123680 |
International delivery is unavailable for this product.
