Bahco Wire Cutters - 180mm
316548
316548
- Broad cushioned grips
- Easy change option - spring loaded or not
- Finest ground cutting edges
Show more
Show less
In our opinion, wire cutters don't come any better than these. Everything about this tool is spot on correct, from the broad cushioned grips, the easy change option of having them spring loaded or not, to the finest graduated grinding of the cutting edges. The specifications state these will cut from 0.5mm² copper to 2.25mm piano wire, in fact the tips are ground fine enough to cut the hair on the back of the hand. Made in Sweden, the Bahco wire cutters are for those who wish to buy only once; you'll never need another. 180mm size.
EAN Barcode | 7314150106493 |
Overall Length | 180 mm |
