Blades for Japanese Folding Pocket Saw - 120mm
AX857232
- Whatever your trade, we have the blade
- Japanese tooth design, fast clean cut
- Impulse-hardened cutting edges for maximum durability
- Blades available for cutting insulation or cardboard
- Plastic pipe, fine pruning, dry wood and curve cutting
- All blades are 120mm long
Show more
Show less
These blades feature impulse-hardened cutting edges for maximum durability. The toothed blades have Japanese style teeth giving a fast, smooth action and leaving a clean result. The range includes blades for cutting insulation or cardboard and one for plastic pipe cutting. There are blades for fine pruning, dry wood, and a keyhole or curve cutting blade as well as replacement general purpose blades. All the blades are 120mm long. Whatever your trade, there is a blade for you.
Length of Blade | 120 mm |
