Bosch C470 Abrasive Sheets 107 x 115mm (Pkt 10)
- Aluminium oxide with hook and loop backing
- Fits 1/4 sheet Palm Sanders
- Size 107 x 115mm
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
Abrasive 1/4 sheet with hook and loop, available in a range of grits. Suitable for sanding wood, paint, varnish and roughcast. The abrasive particles are semi-friable long lasting aluminium oxide grit. A calcium stearate coating minimises clogging, an especially useful feature when working on painted surfaces or other materials that tend to clog. The hook and loop backing offers rapid sheet changes. You can reattach and reuse part used sheets making these discs even more economical. The pre-punched holes allow the use of dust extraction further extending the life of the sheet and keeping your workshop cleaner. Packs of 10.
Abrasive Backing | Paper and Hook and loop |
Abrasive Sheet Size | 107 mm x 115 mm |
Abrasive Type | C470 |
