Bosch BiM C-Tec Precision Plunge Cut Blades (Starlock)
AX933554
AX933554
- Designed for cutting wood and metal with a very precise cut
- Hardwood, laminates, non-ferrous metals, screws, thin steel profiles
- Bi-metal (BiM) ensures long life
- Convex cutting edge, tapered blade for smooth jolt-free cut
- Reinforced mount with anti-vibration slots
- Cutting width 32 or 65mm
- Starlock fitting for maximum power transfer
FEIN 106 HSS Segmented Saw Blade (Starlock)Special Price £18.58 £15.48 was £21.58 £17.98 Save £3.00 £2.50
FEIN 114 Diamond Coated Saw Blade (Starlock)Special Price £44.78 £37.32 was £47.78 £39.82 Save £3.00 £2.50
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Show more
Show less
Designed for cutting wood and metal with a very precise cut. Bi-metal (BiM) ensures long life. The new Curved-Tec cutting edge is convex and the blade is tapered to give a very smooth jolt-free cut. The mount is reinforced with anti-vibration slots. Available with a cutting width of either 32 or 65mm.
This blade is suitable for Bosch, Makita and Fein (10mm) multi-tools and others using the Oscillating Interface System (OIS™) or Starlock fitting which ensures a secure fit with maximum power transfer. An adaptor is also available to fit many other makes.
#AxminsterTools
