Bosch PHO 1500 Planer
- Compact and well balanced
- Takes the hard work out of planing
- Smooth ripple free cuts
- 82mm wide blade, 0- 1.5mm cut depth
- Single 'Woodrazer' blade, makes blade change easy
- Bosch DIY 3 year warranty available (registration required)
Compact and light in weight, the PHO1500 planer takes the work out of hand planing and will plane wood quickly and easily leaving a clean finish. Well balanced, it has a 82mm wide blade and an adjustable cutting depth between 0-1.5mm. Fitted with patented single 'Woodrazer', blade giving a smooth clean cut, a single blade has a big advantage when blade changing; just undo and replace the blade - it is that simple, no height setting. There are three grooves in the base for chamfer work. Parking shoe protects blade when not in use.
This applies to all DIY power tools, garden tools or measuring tools from Bosch. This tool comes with a FREE two-year warranty, to extend your warranty to three years, simply log into MyBosch. and register your tool within four weeks of purchasing it.
Extended warranty includes: repair service, pick-up and returning your defective device for free. Warranty services are all provided by Bosch directly.
To register your tool, please visit MyBosch.Corded or Cordless | Corded |
Cutterblock Speed | 19,500 rpm |
Max Depth of Cut | 1.5 mm |
Max Rebate Depth | 8 mm |
Motor Power | 550 W |
Nett Weight | 2.15 kg |
Number of Knives | 1 |
Planing Width | 82 mm |
Plug Fitted | UK 3 pin plug |
Rating | Home/Light Trade |
Sound Power Level LwA [Uncertainty K] | 97 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 86 dB(A) [3.0 dB] |
Vibration Cutting Wood [Uncertainty K] | 4.5 m/s² [1.5 m/s²] |
Voltage | 230 V |
