Bosch ROBUSTLine 13 Piece HSS-G Drill Bit Set
702183
702183
- Suitable for wood and metal
- 13 piece HSS-G drill bit set, 1.5mm to 6.5mm x 0.5mm steps
- Very clean accurate holes, supplied in a ROBUSTLine case
Show more
Show less
This Bosch ROBUSTLine HSS-G drill bit set is designed to give very clean accurate holes in wood and metal but they will also cut cleanly in plastic and acrylics, sold as a set of 13 these precision ground HSS-G drill bits enable up to 40% faster drilling rates and 50% lower feed pressure than standard ground HSS bits, with a chisel edge and split point drill tip manufactured to DIN338, a very high quality set all contained in a Bosch Robust Line case for durability and ease of use. Sizes contained 1.5 - 6.5mm in .5mm steps.
#AxminsterTools
