Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)
701875
701875
- Acrylic cutting, perspex and polycarbonate
- 2-20mm thick material
- HSS for longlife
- Very clean cutting
- Pack of 5
Show more
Show less
Perspex, polycarbonate, acrylic. Longlife blade for acrylic cutting, the ground and taper ground teeth will give clean cutting in material 2 - 20mm thick.
Blade Type | HSS, Ground and Taper Ground |
Jigsaw Blade Length | 74 mm |
Jigsaw Blade Type | Clean Cuts |
Max Cutting Depth | 20 mm |
Pack Quantity | 5 |
Tooth Pitch \ tpi | 2.12 mm \ 12 tpi |
#AxminsterTools
