Bosch Ultra Thin Metal Cutting Disc 10 in Tin Case - 115mm
- Ultra thin, power saving discs
- Fast and smooth metal cutting, suitable for stainless steel
- 115mm (1.0mm thick) diameter
- 13,300rpm max cutting speed
These ultra thin metal cutting discs cut faster than conventional discs by virtue of their reduced thickness, resulting in smooth, clean cutting. The amount of removed metal is reduced, increasing cutting speed and reducing the heat generated. Particularly suitable for cutting stainless steel without burr formation.
Recommended maximum cutting speed is 13,300rpm. The discs are 1.0mm thick. 22.23mm bore size for standard locking nut angle grinders.
The pack contains 10 Bosch Ultra Thin Metal Cutting Discs in a closable, storage tin case.
Bore Size | 22.23 mm |
Disc Diameter | 115 mm |
EAN Barcode | 3165140668866 |
