Chestnut Tack Cloths
AX554570
AX554570
- A must use product after sanding and before applying finishes
- Picks up, removes and holds dust particles
- Reuseable over and over again, store in plastic bag
Axminster Workshop 19 Piece High Speed Steel Ground Drill Bit SetFrom ÂŁ19.58 ÂŁ16.32
Show more
Show less
Tack Cloths are coated with a special, sticky resin. The resin doesn’t transfer off the cloth but when you wipe it across a surface it removes the fine dust particles that remain after sanding and which can have a detrimental effect on the final finish. Simply wipe over your work after sanding and before applying polishes. Multi-folded each cloth can be re-used many times, place in a plastic bag and seal after use. Not for use on lathe work with the lathe revolving. Supplied in packs of 3 or packs of 10.
