Chestnut Tack Cloths
- A must use product after sanding and before applying finishes
- Picks up, removes and holds dust particles
- Reuseable over and over again, store in plastic bag
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price ÂŁ66.40 ÂŁ55.33 was ÂŁ89.98 ÂŁ74.98 Save ÂŁ23.58 ÂŁ19.65
Axminster Professional Forged Flat Bar Clamp 200 x 80mmSpecial Price ÂŁ11.68 ÂŁ9.73 was ÂŁ15.58 ÂŁ12.98 Save ÂŁ3.90 ÂŁ3.25
Axminster Professional Combination Square Metric 300mmSpecial Price ÂŁ14.98 ÂŁ12.48 was ÂŁ18.88 ÂŁ15.73 Save ÂŁ3.90 ÂŁ3.25
Tack Cloths are coated with a special, sticky resin. The resin doesn’t transfer off the cloth but when you wipe it across a surface it removes the fine dust particles that remain after sanding and which can have a detrimental effect on the final finish. Simply wipe over your work after sanding and before applying polishes. Multi-folded each cloth can be re-used many times, place in a plastic bag and seal after use. Not for use on lathe work with the lathe revolving. Supplied in packs of 3 or packs of 10.
