Co-Matic M3 Baby Power Feed
- Perfect for small spindle moulder, router tables and surface planers
- 3 PU rollers of 76 x 30mm give non-marking grip
- Variable speed, 2 to 12m/min plus reverse
- Unique 3D adjustable arm, with 150mm depth and 260mm reach
- Light duty unit for the hobby and smaller trade user
- Greatly aids safety on moulding operations
A lightweight power feed suitable for use on a small spindle moulder, router table or surface planer. Fitted with variable speed of 2-12m/min + reverse. The three non marking PU rollers are fitted with suspension movement for extra grip and to cope with surface irregularities. The arm is a patented 3D adjustable design for ease of use. The unit can be mounted directly onto the machine or fitted using the Co-Matic mounting base which simply clamps to the machine.
EAN Barcode | 5052511006861 |
Feed Speed | 2 m/min to 12 m/min (var) |
Max Reach | 260 mm |
Max Timber Height | 150 mm |
Model | M3 |
Motor Power | 90 W |
Nett Weight | 12 kg |
Rating | Trade/Professional |
Roller Size | 73 mm x 30 mm |
Voltage | 230 V |
