Artisan Click Pen Kit
AX21807
- Solid brass 10kt gold plated components
- Traditional "click" pen
- Readily available refills
Show more
Show less
Solid brass 10kt gold plated components and dependable transmission make this the choice for those who prefer a traditional "click" pen. The pen uses a readily available standard type refill. Requires 8mm drill bit. When using a mandrel to make this pen the Bushing Set 310380 will also be required.
Bushing Set Order No. | 310380 |
Difficulty | Intermediate |
Drill Bit Required | 8 mm |
Minimum Blank Size | 16 mm x 16 mm x 108 mm |
Pen Type | Click Pen |
Refill Order Number | 506374 or 506375 |
