Scribe Rollerball Pen Kits
AX649864
AX649864
- A smart looking reliable rollerball pen
- Cap can be repositioned to other end of pen body
- Single tube construction
Show more
Show less
The Scribe rollerball kits produce really nice pens and feature a pull off top that can be switched to the other end of the body when writing. An easy to make single tube kit producing a smart looking reliable rollerball pen, it's a joy to write with too. Requires an 8mm drill. When using a mandrel to make these pens, the 701604 Bushing Set will be required. For refills order 340240.
Bushing Set Order No. | 701604 |
Difficulty | Beginner |
Drill Bit Required | 8 mm |
Minimum Blank Size | 19 mm x 19 mm x 82 mm |
Pen Type | Rollerball Pen |
Refill Order Number | 340240 |
#AxminsterTools
