Crown 5 Piece Cryo M42 Woodturning Tool Set
105915
From £369.98 £308.32
9 Reviews
  • 19mm roughing gouge and 19mm skew chisel
  • 9.5mm spindle and 9.5mm bowl gouges
  • 4.8mm diamond parting tool
  • M42 HSS cobalt steel for ultimate tool life
  • Cryogenic treatment for increased edge retention
  • Excellent choice offering many years of good service
  • Well balanced with comfortably shaped ash handles
Produce clean, smooth cuts and turn for long periods of time!
More time turning
Hardened to 66/69 HRC, you’ll spend less time at the grinder and more time at your lathe.
Long lasting, sharp cutting edge
M42 HSS lasts much longer than standard HSS; this combined with Crown’s Cryogenic process makes the steel harder and more wear resistant.
Turn for long periods at a time
The handle has an ergonomic design making it comfortable to hold and is in proportion to the blade to keep it well balanced whilst in use.
M42 steel gives you a razor sharp edge allowing you to produce very clean cuts.
The Crown Cryo M42 range has really changed how I work, they hold a razor sharp edge for far longer, allowing me to concentrate on the work I'm producing and not worrying about having a dull tool every five minutes. Sculpturist, Max Bainbridge explaining why he loves the Cryo M42 tools
With their M42 blades and well-shaped ash handles, these tools will become firm favourites. This unique set comprises a 19mm roughing gouge, 9.5mm spindle and 9.5mm bowl gouges, 4.8mm diamond parting tool and a 19mm skew chisel.
Turning tools made with cryogenically treated M42 cobalt HSS will give you a lifetime of good service and by their very nature ensure you spend more time at the lathe and less time at the sharpening station. The M42 steel gives you a tool with unrivalled edge retention and the ultimate tool life. M42 is a premium, high-speed steel alloy with molybdenum and 8% cobalt. One of its most significant properties is high wear resistance even on tough and abrasive timbers. The cutting edges on tools made from M42 high-speed steel stay sharp and hard even after prolonged hard usage.
British Made British Made
5.00 9
