Easy Wood Tools Ci5 Carbide Cutter - Round
- Fits: Micro Easy Finisher, Mini Easy Finisher
- Fits: all Mini Easy Hollowers and Mid-Size Easy Hollowers
- 8.9mm diameter, solid carbide
- Optimum grade of carbide, long lasting cutting edge
- Proprietary grinding for the sharpest edge possible.
- Precision ground finish
- Easy Wood Tools tips are 100% made in the USA
The Ci5 solid carbide cutter is 8.9mm diameter. It fits the Micro Easy Finisher, Mini Easy Finisher, Mini Easy Hollowers #1, #2, #3, and Mid-Size Easy Hollowers #1, #2, #3.
The standard carbide cutters provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
