Easy Wood Tools Ci6-R1-NR Carbide Cutter 1" Negative Rake
- Fits the Micro Easy Rougher
- 9.3mm square, with slightly curved edges
- Negative rake for acrylics, resin and very hard woods
- Optimum grade of carbide, long lasting cutting edge
- Proprietary grinding for the sharpest edge possible
- Precision ground finish
- Easy Wood Tools tips are 100% made in the USA
The Ci6-R1-NR negative rake carbide tip is 9.3mm square. It fits the Micro Easy Rougher.
Negative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.
Each of the four edges is slightly curved with a radius of 1", hence the R1 suffix. The radius along the edge, minimises the risk of a catch from a sharp corner when moving the chisel from side-to-side.
When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
