Easy Wood Tools Ci6-SQ Carbide Cutter Square
- Fits the Micro Easy Rougher
- 9.3mm square, solid carbide
- Optimum grade of carbide, long lasting cutting edge
- Proprietary grinding for the sharpest edge possible.
- Precision ground finish
- Easy Wood Tools tips are 100% made in the USA
The Ci6 solid carbide tip is 9.3mm square. It fits the Micro Easy Rougher
The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
EAN Barcode | 811269020896 |
