Entropy Clear Casting Slow Hardener
From £17.58 £14.65
2 Reviews
  • Slow curing hardener
  • To be used with Entropy Clear Casting Epoxy Resin
  • For high-build casting epoxy applications
  • Ideal for mass castings
The next generation of Resin
A natural bio-based epoxy ideal for the conscientious woodturner, woodworker, crafter and artisan.
High performing
Crystal clear, self-levelling and extremely durable. This system features quick air-release and world-class UV resistance. Professionals all over the world use this innovative epoxy to create, build and beautify the world around them.
Natural innovation
Bio-based, non-toxic epoxy which is an environmentally friendly alternative to other epoxy resins on the market. Being non-toxic it is also safer to use.
Ideal for woodworkers
Water-clear and UV-stabilised for applications that require a low-colour and low-yellowing, such as when you want to preserve the natural colouring of wood. CLR works with a choice of hardeners to match your woodworking methods.
Versatile creations
Low colour and low viscosity allow for bubble-free, crystal-clear castings. It’s ideal for art and hobby applications such as jewellery, river tables, and other casting or embedding projects that call for clear casting, clear coating, adding depth, showcasing vibrant colours, or creating sheen.
Environmentally friendlier
Even biobased epoxy impacts the environment, but Entropy Resins are formulated for reduced environmental impact throughout their life cycle. Certified by the USDA (US Department of Agriculture BioPreferred program). Entropy Resins also participates in the ‘1% for the Planet’ fund throughout the United States and Europe.
More sustainable
With 30% bio-based content this formula is manufactured with renewable resources to the highest extent possible. By using green chemistry techniques less energy is required during production, which minimises harmful by-products and reduces greenhouse gas emissions.
Choice of hardeners (sold separately)
CLR works with a choice of hardeners to match your woodworking methods. It has an ideal viscosity for a wide range of applications that use hand layup techniques with fast, room-temperature cures.
Entropy is shaping the next generation of epoxy with their bio-based clear casting resins. Created and manufactured in-house, by a family-run and employee-owned team, Entropy Resins are high-performing, environmentally friendlier and more sustainable. The slow hardener is to be used with the Entropy Clear Casting Resin (sold separately). A fast hardener is also available.
This Slow Cure has a 360 min setting time and 72 hr tack-free time*. A Full Cure of 7 days @ 25°C is recommended. Ideal for high-build casting epoxy applications.
With 30% Bio-based content this formula is manufactured with renewable resources to the highest extent possible. Through green chemistry, bio-based and rapidly renewable raw materials, and efficient manufacturing, energy is conserved, minimise harmful by-products, and reducing greenhouse gas emissions during product processing. USDA Bio-Preferred Certified.
Axminster recommends a minimum of FFP2 respirator and eye protection when sanding or cutting resin.
*setting and tack-free time can vary depending on volume and room temp. These tests were conducted at 95ºF/35ºC
5.00 2
