Espresso Coffee Tamper Kit - 51mm
- Perfect accessory for your at home coffee machine
- Made from durable, food-safe Stainless Steel
- Easy to turn
Micro-Mesh Soft Touch Abrasive Pads 50 x 50mm - Mixed (Pkt 9)From £15.58 £12.98
Make great espresso coffee with this beautiful handmade tamper. The solid, professionally machine milled FDA 304 18-8 food grade Stainless Steel tamper is the perfect piece to add to your at-home barista set up. Make your handle using traditional Bottle Stopper kit accessories. Included is a 3/8" threaded insert for easy turning and assembly. Tamper fits 51mm Baskets.
Difficulty | Beginner |
Drill Bit Required | 1/2" |
EAN Barcode | 810011936751 |
Minimum Blank Size | 1-1/2" x 1-1/2" x variable length |
